Old-Biscuit
Jul 07, 2014Explorer III
DiskDoctr wrote:
Hmmm...black sludge can be manganese, which can absolutely make the water smell bad.
Can you replace drain plug with ALUMINUM anode? Aluminum will not react the same way with that water.
How does your electric heating element look? Maybe replace it, too, both AFTER cleaning the tank.
Atwood WH tank IS aluminum......doesn't need/require an anode rod (even though aftermarket sells them :S)
Tank just needs a good, thorough cleaning
OP
If the element is a bolt on type part number is 91580
If element is screw in type part number is 92249
Both are 1400W
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
