randyspiess
Oct 02, 2013Explorer
bad taste from city water connection
I have been having a bad taste in my water, sort of an inky/chemical taste, but it only happens when I am connected to a hose connection in a park and using city water. It has happened at several different parks so it is not the local waters problem and it doesn't happen when using water from the holding tank. I have sterilized he tank and lines several times but the problem returns quickly. I have also changed the hose so don't think that is the culprit either. Any suggestions what is causing it and how to cure it?
