Horsedoc
Jul 17, 2017Explorer II
look at the stud on the door frame that the latch on the door wraps around when the door is closed. I had a similar situation on my Ford 250. Somehow the plastic or vinyl that encircles it had either broken or split off and the door would not close tight. Drove me bonkers for a while and I finally figured it out. I could not figure out what to do. Finally the old redneck country boy genes kicked in and I wrapped it in electrical tape (same width) until it was a thick as the missing band - several layers. Worked great and no more noise. The door was not being held closed tight enough.
