bucky
Jul 18, 2017Explorer II
AJBert wrote:
If none of the above works out, take a look at the hinge pin holes. They may have worn themselves out throwing off the alignment.
This is a common problem with older GMs. Lift the rear edge of the door by hand and watch the hinge pins for movement. If they are loose the door is sagging. Another thought is that the striker is out of adjustment, worn, or loose.
To eliminate the w/s mldg put some painters tape along the mldg gap to body and w/s and drive it.
