schlep1967
Feb 01, 2023Nomad
Your best bet is to replace the cables. Look up "BAL 22305 Cable Repair Kit Accuslide". There are plenty of videos on youtube showing how to do it. Aside from the kit you will need cable cutters and a swaging tool.
I wouldn't move the chains without actually talking to BAL. You don't want to run the sprocket out of chain and cause a bind.
Unless the sprockets already jumped links you should be able to make the new cables the correct length and get everything in adjustment.
If you are not sure of where the chains should be in relation to the slide position, again, I would contact BAL for guidance.
