schlep1967
Feb 01, 2023Nomad
Remember this is an 8 cable system 4 that pull out and 4 that pull in. It is a give and take setup. Both sides should be equally tight with about a 1/2 inch of movement on the "loose" side of the cable. I.e. When the slide is in, the cable you can see on the inside is the loose cable. When the slide is out, the cable you can see outside is the loose cable.
Nothing should be "banjo tight".
