schlep1967
Feb 02, 2023Nomad
I think I see the difference now between the bedroom wardrobe slide and the one you are having problems with. The wardrobe slide motor is installed at an angle with the motor lower than the gear. That gives the clearance for the adjustment bracket.
Since you can't really re-drill the mounting holes, I would suggest elongating the holes on the left side of the mounting bracket so you can slide the motor end down. That should give you the clearance you need.
Most likely you will have to elongate all but one of the holes.
