schlep1967
Feb 02, 2023Nomad
StirCrazy wrote:
as long as all your pullys and such are good, I would remove some chain links. but I would check all the piviot points and anchor points first to make sure there isn't anything wrong there. it could be that who ever put it togeather just mounted stuff in slightly wrong places causeing excess cable or the cable streched a bit from use.
Removing links won't change the relationship between the chain and the motor. And he will need the range of motion to move the slide all the way out/in.
On a short in length but deep slide the ends of the chain have to go past the motor.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
