centerline's avatar
centerline
BAL Accu-Slide units... removal procedure?
my 5th wheel is equipped with the norco accu-slide out, and I need to remove it to reinforce the bottom of it...
does anyone have experience with this procedure?
over time, it seems it has gotten moisture in the bottom of it and now it is sagging on its rollers as the floor is being pushed upwards into the the slider. so I need to remove it and replace the supporting structure that is above the aluminum panel, which im sure is OSB, (which is only slightly better than particle board and should never have been used in any type of RV) with a good strong piece of HDP plywood...
if anyone has done this, or even just removed and replaced an accu-slide brand unit I would like to hear from you... Thanks
No RepliesBe the first to reply
