scrubjaysnest
Mar 25, 2018Explorer
While a tenth volt doesn't look like much, you need to look at the entire math involved. voltage*amps = watts; if you have 0.1 volt times 10 amps that is a 1 watt unbalance between the batteries whether it is charge or discharge. While it doesn't sound like a lot over time it will translate into a possible early battery failure because of the accumulative affects to the battery chemistry.
For a cheap battery not such a big deal but if your talking high end L-16's it is.
The question is the voltage difference due to connection resulting in heat loss or just slightly longer wire.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
