Bumpyroad
Sep 04, 2013Explorer
69 Avion wrote:Raften wrote:
Just a observation about having just a hitch pin on your 5/8 pin. Several years ago a friend of a friend was killed when a stinger came out on the highway and hit her. The most likely reason is someone pulled the pin and the big pin worked it's way out and a bump allowed the stinger to fall out.
I use a grade 8 bolt and nut with a set screw safety. No one is going to get that out unless they have a hex wrench in hand.
I always use a heavy duty hitch pin with built in lock. Hitches are too expensive to leave them unlocked.
yep, I have always used a lockable hitch pin. when I towed a toad I also had two of them at the connection of tow bar and toad.
bumpy
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
