BFL13
Mar 25, 2018Explorer II
Beware of that status gauge. You can see if it tells the truth once you do your test.
To be clear, you will get to 50% by SG and voltage readings after a certain time. So if it takes 8 hours, that is 8 x 7.5 = 60AH for 50%. So your 100% full is 120AH. Rating as new is 150AH so you are at 120/150= 80%
Same as 8 hours instead of 10, so you can just use the time to get your percentage of rated SOC.
I am thinking that gizmo is going to give the wrong answer unless it already knows what the actual AH capacity of the batteries is, and how can it know that, when you don't yet?
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
