lawrosa
Mar 25, 2018Explorer
BFL13 wrote:lawrosa wrote:
Just a side note. Actual volts @ batts are 12.45. So MT50 showing 12.4 is closer to accurate. The balmer shows 12.35 v..
Probably the 11 feet of 12 gauge wire for the balmer. Where the MT50 is off the solar controller with RJ45. And the controller is 4 ft from batts with 8 gauge.
And thats how I usually gauges it when boondocking. If my inside meters read 12.2 or 12.1 I can be assured the actual batt voltage was/is higher
I hope the solar controller is not connected to the panels while you are running this test!
No nothing is connected
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
