BFL13
Mar 25, 2018Explorer II
You should go till you hit SG 1.200 however long it takes. Use a flashlight. :) You know the AH down at 7 hours, but you don't know your SOC by SG unless you have a table for your batts and not the Trojan table, which does not apply to yours. 1.200 as a marker for 50% is probably close, but what is the SG for 60%?
70% at 7 hours means you are looking good, but more time will get you a better idea. Do check a couple of cells in each battery to make sure they are all about the same.
1.225 at 7 hours compares with my 1.225 at 8 hours, so you might still hit 1.200 a bit early.(as expected with older batteries) You need to know that timing, which you can't if you quit early.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
