scrubjaysnest
Aug 07, 2016Explorer
Kayteg1 wrote:
Maybe your dealer knows something about battery charging, maybe not.
The only clear answer will give you a voltmeter hooked up to battery.
If your charger stops charging at 13.5V - it is good one. If goes above 14V -it is killing the battery.
Same with solar charging. You want the batteries to be around 13V in the afternoon. Check the battery manufacturer site what they consider discharged battery and go from there.
This is not correct except for the part about checking the manufacturer site for proper charging.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
