webrx
Aug 27, 2016Explorer
if you have 300 ma parasitic draw you need to replace 7.2 amps a day (.3 x 24)
if you get 6 hours of good sunlight to charge you battery with, you theoretically (panel efficiency comes in here) need 1.2 amps charging an hour.
a 15 watt panel will put out 1.25 amps (15 / 2) again - theoretically
Reality, is a 40 to 50 watt is in my opinion the bare minimum you need to make up for parasitic loads and running the water pump for a couple showers, etc. A 40w will (depending on sun conditions) top off your battery if you don't waste a lot of power and use less than say 20 amps a day. At a minimum it will allow you to replace some of what you use each day.
100 watts / 12v = 8.3 amps an hour theoretically (multiple by .6 to get closer to actual which will be around 5 amps) 5 amps x 6 hours will get your 30 amps to charge your battery with. (you will get more than this as you will have a couple less than perfect sun hours on either side of your 6 hours but this is conservative so a good value to use)
to sum up, if you are going to buy portable solar, I would recommend that you go a minimum of 100 watts, and if you are a heavier user of 12v or are in cloudy conditions or surrounded by trees, etc, then you will need more.
Again, this is what my experience has shown, I am not a solar expert, nor electrical engineer, and I dont play one on TV - so YMMV.
