Boins's avatar
Boins
Basic battery charging and solar question
I have a Surveyor 245BHS with 2 6v batteries wired in series. The RV dealer told me that when I'm plugged in to charge, the trailer doesn't recognize when the batteries are fully charged and will keep charging. Off season, I always remove the batteries and periodically set 'em up with a battery tender.
If the trailer does over charge, what is a simple option to create an automatic cut off once the batteries are charged.
Also, I do a lot of dry camping and don't have a generator (I don't need to run the appliances or AC). Is there a simple solar setup that just gives a trickle charge to the batteries while camping? I'm not expecting a solar setup that does a fast recharge, just a trickle.
I'm new to this aspect of battery maintenance and just don't know what things I need to do this properly.
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
