Boon_Docker
Jun 08, 2020Explorer III
Yes, sounds like a good plan. You will have only a 0.2 volt voltage drop from the panels to the controller by running in series.
I would install an inline circuit breaker instead of a fuse between the panels and controller. That way the circuit is protected plus you can also take the panels out of circuit if need be.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
