time2roll
Jun 08, 2020Nomad
24.3 Voc seems low for a 24v panel and high for a 12v panel. Double check the spec.
Take additional precautions with 75+ volts. This can bite pretty hard.
#10 down to the controller is fine. #8 is fine but seems a bit light... If buying wire I would go #6.
Fuse from the panels is not needed but can serve as a disconnect. Verify it is rated for the voltage.
Probably only need 40 amp controller unless you expect to expand.
Looks like a great system.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
