Boon_Docker
Jun 08, 2020Explorer III
freetheheal wrote:
Thanks for the added clarity. Sounds like I should run #8 wire and I can get MC4 connectors for it which is nice. I also may need to think about adding a 4th panel. The circuit breaker is also nice to take the panels off line if I need to.
Running your panels in series (75 volts @ 8 amps) for 25 feet.
10AWG wire gives a voltage drop of 0.20 volts.
8AWG gives a voltage drop of 0.13 volts.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
