mkirsch
Nov 05, 2015Nomad II
No. If you connect to the + on the "battery #2" battery, you will only get 6V.
When connected in series, the battery voltages add up. All positive connections must be made to "battery #1", and negative connections made to "battery #2" to get 12V.
Many of those cables are redundant, so you should be able to eliminate some. You can eliminate the parallel cables that connect to the other battery, for example.
