WyoTraveler
Nov 05, 2015Explorer
westend wrote:WyoTraveler wrote:No duct tape on electrical connections, please! The tape is conductive. There are labels available for marking wires.
Lots of good info posted. If some wires are too short don't splice and tape. Properly run them to a terminal block. Safer and if you have any problems later it is easier to trouble shoot problems. Label the wires. I use duck tape over insulated cables and felt tip pen to label. Otherwise you'll be untaping splices later and wondering where the @#$@@& did those wires go. And your DW will say you should have labeled them. :B
Maybe I wasn't clear. I'm not using it as electrical tape. I put the duck tape over the insulated wire back a few inches from the connection. It is used for labeling not as an insulation. Sorry it wasn't clear. I label any wires I remove and replace on anything I work on. Worked in electronics too long not to label wires.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
