full_mosey
Mar 22, 2014Explorer
Unyalli wrote:
The whole RV converter topic is so dismal. The only way I can find to properly care for your batteries is a quality solar charge controller with temperature compensation or a quality inverter/charger with temperature compensation. The paramode is so close but they cap the voltage at 14.4. Uuugg!!! Why!!
I agree completely about the outperformance of solar controllers over converter/chargers. It is easy to explain when you consider that converters are primarily purposed as a power supply to provide 13.6V when connected to shore power, or a generator. Any charging function is simply a flimsy tack-on.
A solar controller is primarily a charger and is less concerned with the power supply function and could care less about the standard 13.6V found in the typical converter. There is NO correct fixed voltage for proper battery charging across a range of battery temperatures, but 14.4V certainly beats out 13.6V for a cold battery.
Since you are posting with a WY based account, I can see how you feel 14.4V is too low. FYI, my MS TS-45 PWM recorded 15.45V charging the morning we experienced 6F overnight in OKC.
For the OP in LA(Louisiana), a 14.6V fixed Voltage might be totally inappropriate for longer battery life. I wouldn't leave that charger unattended like I do with my solar controller. I would have no problem leaving the charger I recommended unattended anywhere.
HTH;
John
