BFL13
Mar 22, 2014Explorer II
full_mosey wrote:
Oh please get a proper temperature conpensating charger for the LA climate. The charger(s) that have been recommended will dry out your batteries because they use EXCESSIVE Volts for your location. A proper charger will monitor the actual battery temperature and use the correct Volts to prevent excessive bubbling during charging.
I recommend, and continue to recommend, the Multistage 55 Amp Parallax ParaMode converter charger with Temperature Compensation.
Warm(er) batteries do not have a longer life with High Voltage chargers like the Powermax Boondocker type of charger which boosts voltage.
My AGMs charge just fine when they are 110F with Volts in the low 13s.
Many posters are from the Pacific NorthWest where temps soar up to 90F for a few minutes daily after July 4th. That is not going to result in a warm battery like you will experience in LA. They need those 14.6V, you do not.
HTH;
John
Makes sense for those who live down south in the PNW! (Which is in the USA--although not Alaska for some strange reason)
Here in BC, we also need those higher voltages though. I like my adjustable voltage PowerMax unit, which lets me pick whatever voltage I want for charging or floating depending on the prevailing temps at the time.
