12rvjoe's avatar
12rvjoe
Batteries question
i was wondering if there would be issues of adding two six volt batteries independent of the factory twelve volt set up. I want to add the six volts and charge them using a generator , until I can get solar set up and run cable to the inverter only and plug in the shore power cord to the inverter. thoughts ?
TIA, Joe
  • ^^^^ yes, although there are probably a few other items on that branch circuit.
  • Hi,
    I have two unequal battery banks. I put the switch(es) between the banks and the inverter. I can use either one, or both to power the inverter. I can use one bank and charge the other. It is cheaper and more flexible than an A,B,Both,Off type of switch.
    And yes, you can turn off the converter at the breaker panel. Mine is a plug in unit so I simply have a default of unplugged. That leaves me with only the fridge to move to propane.
    12rvjoe wrote:
    Thanks for the input, Don. Could you please elaborate re the inverter and switch ...
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
