pianotuna
Dec 25, 2014Nomad III
Hi RJ,
3 amps x 12 volts = 36 watts
5 amps x 12 volts = 50 watts
The point I was trying to drive home is that the OP doesn't have much charging happening from solar, and not nearly enough to be effective.
If you bothered to read the entire thread you would have seen I recommended between 400 and 150 watts.
RJsfishin wrote:
Quote:
3 amps corresponds to about 36 watts. 5 is more like 60 watts-
Get w/ reality !!
3 amps is more like 55 watts,...and 5 amps is more like 100 watts
Always quoting specs under perfect ideal conditions, is not impressing anyone, and more misleading them into thinking their solar system is not performing normally.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
