JiminDenver
Dec 25, 2014Explorer II
Not all corrosion can be seen. I had to help my FIL with his car that would not start even with a new starter and battery. I was about to pull the starter when I noticed a small bump in the covering of the cable. I ended up cutting two inches off of the cable to get back to clean wire, after that the car fired right up. Your charge controller may be putting out 5 amps, but is the battery getting it.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
