twvette's avatar
twvette
Batteries/solar not holding up, troubleshooting help please
I have no luck getting batteries to hold up it seems. Had a couple different RV's and different setups too (wet cell, lifeline golf cart, gel deep cycle batteries)and none have ever held up well.
Anyways, here is what I have now:
- Onan 5500 gen
- Iota DLS-45 converter
- Three Optima Bluetop D31M (less than a year old)
- Large solar panel (or maybe it is even two combined together?)
- Shell Solar RV 20 solar controller /monitor
- Only camp in AZ so almost always get great solar
Worked great in beginning but seem to be on downward spiral. I now can't get through even a mildly cold night (mid 40's) of heater use only without them dying. I have had to run the generator much more even with the solar system to get/keep them fairly charged whereas before the solar panel would generally give me full recovery from typical day and night use.
Here are some observations:
- I previously got 13.4 volts or higher when running the generator but now only see 13.0, and settles at about 12.7v a little while after shutting off generator
- When shutting off generator I never get much more than an "OK" status on my monitor whereas as before I would typically be at "GOOD" or a few LEDs above at least for a while
- Connected an automotive style battery charger after charging with generator for a while and it also claimed the batteries were fully charged.
Here are some questions/concerns:
- Is the solar system overcharging my batteries slowly killing them?
- I do not have the Iota IQ4 smart charge option as far as I can tell, perhaps this will help? Seems like a long shot as had this in previous RV and did not see any real improvement but maybe would prevent Onan 5500 from improperly charging gel batteries this time around?
- Generator/Iota DLS-45 issue in general? All my RV's have had this same setup
- Is the Shell Solar RV 20 junk or good? I did not purchase or install this system.
- Can anyone tell from pics below which solar panels I might have? I have no clue on make/model/output and no markings on them even underneath!
- Maybe I am leaking back power through the solar panels at night?
- Would putting an ammeter inline help figure this out? Maybe a Doc Wattson http://www.rc-electronics-usa.com/ammeters/rv-battery-monitor.html
- How to test my batteries to see if they are still good? Maybe only one battery is bad?
Thanks for any help!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
