BFL13
Mar 28, 2020Explorer II
Deka flooded Vabs is 14.4-14.7v also higher than their AGM Vabs
https://www.eastpennmanufacturing.com/wp-content/uploads/Renewable-Energy-Charging-Parameters-1913.pdf
However, that 14.4-14.7 is lower than for these Stark AGMs at 14.6-14.8 ( my 100AH Starks say 14.5-14.9 same as those UB121000s)
http://www.wegosolar.com/products.php?product=SKR%252d125AGM-Stark-AGM-12V-Solar-Battery-Sealed-125A
Which only proves again that there is no rule that all AGMs use lower voltages than flooded. BUT it does show again that you really need to look up the charging specs for whatever battery you have.
If your charger has AGM, GEL, and WET settings where the AGM voltage is lower than the WET voltage, and your AGM spec is actually higher like the above examples, then you would know to use the WET setting with your AGMs. (If that WET setting matches)
Best thing is to have an adjustable voltage charger so you can meet any spec any battery you buy might have.
