mena661
Jul 30, 2013Explorer
8 gauge is not near enough. No inverter manufacturer recommends that small of wire size for their large inverters. How many feet of wire is that #8? Even at 1 foot, you're losing nearly .2 volt. Also, with draw, that wire could melt considering it's only rated to 68 amps and that's with 105C insulation. Stop using high draw appliances immediately until you can upgrade to larger wiring. Like smk said, 2/0 is the minimum.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
