- wa8yxmExplorer IIIWell, there are, of course, no six volt batteries in RV's.. Only outside of RV's.
So here is your answer
What you have now
+battery-
+battery-
+battery-
+battery-
What you need to do (note you can likely get by on just two pair)
+bat-+ery-
+bat-+ery-
+bat-+ery-
+bat-+ery-
+bat-+ery-
Where each half of the 12 volt battery (Bat or Ery) is in fact a six volt battery,, The missing "T" is the jumper wire. - BoonHaulerExplorer
pianotuna wrote:
Hi shinybeast,
Yes, this is the only way to do it in a balanced manner.shinybeast wrote:
Jeez, didn't catch that it was only 6v. So more like this? Don't be intimidated by my artistic skills!
X2....and remember, keep all the cable lenghts the same. - pianotunaNomad IIIHi shinybeast,
Jeez, didn't catch that it was only 6v. So more like this? Don't be intimidated by my artistic skills! - shinybeastExplorerGreat, thanks all! New to this forum, very enjoyable and informative.
- mena661Explorer
shinybeast wrote:
That looks like it.
Jeez, didn't catch that it was only 6v. So more like this? Don't be intimidated by my artistic skills! - mena661Explorer
BFL13 wrote:
LOL! I do miss the ole girl.
Mena, you keep showing pictures of that other guy's new Paramode. :)sh410 wrote:
Thanks. I was not clear with my post.
If the batteries are 6V that diagram will only give 6V total.
Each pair of 6Vs need to hooked up the the respective buss bar. - 2oldmanExplorer II
skipnchar wrote:
Yep. Just think of it as 3-12v batteries in 6 pieces.
Each set of 6 volt batteries is made into a large 12 volt then you wire the 12 volt sets together just as any other 12 volt batteries to maintain 12 volts as the output. - sh410Explorer
shinybeast wrote:
So like this but with extra two batteries obviously. I wanted to avoid the pos/neg busses but if this is the only way...
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
