SCVJeff, BoonHauler
If you guys have the time, it would be really interesting to see the measurement across the flats for all the Mic-120 dies and the Quick Crimp 250 dies.
Interestingly enough, the Quick Crimp 250 seems to have MM2 number setting too. I wonder if the die sizes match up to the quick Crimp?
CVJeff:
Assuming the MM2 70 die has the same measurement as the Quck Cable Orange 70 die it looks like you ended up using the suggested die for a tube style lug. I suspect that's what you have there since there's a flare at the end. I'm pretty sure the thicker cast ones have a bevel.
