bratastic's avatar
bratastic
Battery charged but RV won't run on house batteries
Hello, I have a 2007 Itasca Navion. I noticed my RV would only run on shore power. long story short, i ended up replacing my batteries and converter. I can see that converter is generating 13 plus volts (as expected) but when I test the positive across both batteries doesn't indicate that the 13 volts are getting to the batteries to charge them. Which btw I realized I have a solar panel connected which I believe is what is charging the batteries....the batteries have juice (not sure if it's just because they are new and/or if the solar is charging) but even then if I unplug from shore no juice (no lights, no pump, etc). I think I have two issues 1) converter power is not getting to batteries to charge them (I think it may never have and it's always been the solar system that I didn't know was connected) and 2) Even thought the batteries have power, they are not powering anything. Any ideas? (we also checked fuses and breakers and reset the GFI outlet in my bathroom)
  • Turn off or disconnect the solar as it's confusing the issue. Unplug shore power and it the battery voltage is above 12.7V add a load (or wait overnight) until the surface charge is depleted and you have 12.7V.
    Now plug in shore power and you should see 13V+ at the converter and 12.7 at the battery. Track down where the open circuit is located.
    Tip: Measure voltage from a frame ground ONLY and not a ground wire. You might have a ground problem and using a ground wire can mask the problem. I carry a 40' wire with clips for this purpose. Any size wire will do as voltmeters draws are extremely small.
    Also consider adding a battery monitor. There are several inexpensive ones available and have been posted on other threads. A AC/DC clamp on amp meter is another good option. From your description you'll see 0A into the battery.
  • I missed the part that there was solar involved. Yes definitely turn off or disconnect the solar first.
  • I have a couple of questions for you, first is the solar system you refer to the 10 watt that Winnebago was installing on a lot of coaches. second is do you have the electrical schematics for your rig?
    If the answer to the first is yes, I don't think that the solar system is at fault. Don't worry about it.
    If the answer to the second is yes, you should look at the battery switches how they are operating, I would bet the converter is supplying powere to one of the switches and that switch is bad. By switch, I mean solenoid, not toggle or other manually operated switch. I would start there looking for trouble. If the answer is no, download it from Winnebagoind.com. You'll find it under the resources tab.
    The circuits are right there and should be easy to trouble shoot.
    I have a third question, does your rig charge both batteries and the 12 volt system work when the engine is running and you are disconnected from shore power?
  • Why would a mfg install a solenoid between the charger and house battery?
    A solenoid between 2 battery banks is however useful.
  • enblethen wrote:
    I beleive D.E. Bishop is talking about a battery disconnect
    You are quite right.
    I'm sorry but I did say Battery Switches. The switch on the wall is just an activate switch and the two solenoids in most Winnies are often on here called switches. Of the two in the battery compartment, one is a single action continuous duty solenoid and the other is usually called a latching relay(or switch, or Solenoid. Folks use different names but most often Winnie uses an intelletec latching solenoid.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
