CJW8
Oct 14, 2015Explorer
The charger in your link is only 4 amps. It is about the right size for a small motor cycle battery. If your battery is down to 12 volts resting voltage and it is the size of a car battery (group 24, 27, 29 or 31) it will take several hours for it to charge with no load being used for it to fully charge your battery. I'd suggest a 20-40 amp charger for a single battery. The charger you propose is a 4 amp charger for $76. That is pretty steep.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
