time2roll
Oct 14, 2015Nomad
4 amps is a bit light but may work fine depending on the programming. Charger will need to hold absorption voltage for 12 to 24+ hours.
I recommend the 10 amp for about $100. A good converter will be $150 to $200.
If using a generator you really should have 15 to 20 amps per battery or the run time will be rather extended.
A 100 watt solar panel could serve you well.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
