Dandy_Dan
Sep 22, 2015Explorer
Bluebeard, I think the simple answer to this is YES to both. On shore power your converter/inverter will charge the battery and when hooked to the tow vehicle will also charge the battery if you have the hot line on the tow vehicle hooked. Some vehicles come with plug already wired and you might have to put a fuse in the fuse panel.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
