Grey_Mountain's avatar
Sep 05, 2019
Battery Charging Problem
Came home after a short trip, plugged unit into 50amp shore power. Batteries are not charging. Circuit breaker on the Freedom 528 Inverter continues to pop. Did not have this problem when plugged into shore power on my last trip.
Also, doesn't appear that my batteries are being charged on my generator, or from the engine.
Suggestions?
Taking the unit in next week to have the fixit guy look at it, but would appreciate any insight here.
Thanks.
GM
  • Battery POS cable should have an in-line fuse OR DC Circuit Breaker....check to make sure it is not blownm/tripped
    Battery Low Voltage.......Inverter trips??
  • Good first step is to have the batteries load tested by a good battery shop. Auto stores are not good battery stores.
    Then check for any obvious wiring shorts and if OK then next up is the charger/inverter.
    W/O gen or shore power does the inverter work?
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
