dccamper's avatar
dccamper
Battery Charging Troubleshooting
Here’s my equipment:
Battery Monitor with shunt. ( not a Victron or Trimetric but seems to be accurate)
Trojan T-105’s x 2 ( one month old, water level is good)
Progressive Dynamics 55 amp converter with charge wizard( I replaced a WFCO)
200 watts portable solar.
6 AWG cables from converter to battery via battery disconnect switch. Looks like about a 5-6 ft run.
I have a new Fifth Wheel. It appears that my batteries are not charging above 90% using the converter. Seems the charging amperage is minuscule above about 87% or so. On the converter a whole day goes up like .4 %. Today my monitor basically showed no charge from converter (less than 1 amo) I hooked up solar today and was getting about .5 Amps charging but was charging. I did not have a battery monitor on my previous fifth wheel but the voltage and behavior of the charge wizard indicated I was charging to 100% after a couple days. Is it possible something like the battery cutoff is retarding charging from the converter?
  • You won't know a thing for sure until you put an hydrometer in those batts and get the truth about where you are at.
    Also you need the voltage at the battery posts to compare with the voltage at the converter terminals, which you get from your digital multimeter.
    After that, you can judge whether your monitor is accurate.
  • Mount four hundred solar watts on the roof. Connect to a good controller then to the batteries all with adequate wiring. Forget about the converter.
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: May 15, 2020
