dccamper's avatar
dccamper
Battery Charging Troubleshooting
Here’s my equipment:
Battery Monitor with shunt. ( not a Victron or Trimetric but seems to be accurate)
Trojan T-105’s x 2 ( one month old, water level is good)
Progressive Dynamics 55 amp converter with charge wizard( I replaced a WFCO)
200 watts portable solar.
6 AWG cables from converter to battery via battery disconnect switch. Looks like about a 5-6 ft run.
I have a new Fifth Wheel. It appears that my batteries are not charging above 90% using the converter. Seems the charging amperage is minuscule above about 87% or so. On the converter a whole day goes up like .4 %. Today my monitor basically showed no charge from converter (less than 1 amo) I hooked up solar today and was getting about .5 Amps charging but was charging. I did not have a battery monitor on my previous fifth wheel but the voltage and behavior of the charge wizard indicated I was charging to 100% after a couple days. Is it possible something like the battery cutoff is retarding charging from the converter?
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
