RetiredHoser's avatar
RetiredHoser
Battery connect/disconnect and fridge
I am currently on my first adventure and I am half way through a 12 day road trip .I had the fridge working on house batteries and propane and the battery switch was on connect to make the fridge work as it would not work on battery disconnect when we were driving.When we ended our day in a Walmart lot the house batteries were completely dead and nothing worked.I had to start the engine to fire up the generator to plug in a battery charger to charge the house batteries.Is this normal procedure?What do others do if they want the fridge working while they drive and there is no plug in at the end of the day.
  • Ava,it is a 2 way fridge.Thanks for the information.While we are driving we have been alternating battery connect/disconnect at 1 hour intervals.
  • If it not a three way fridge , 120v 12 v, and propane, then it won't work when driving.
  • You really did not give us much info on what you have. But it appears that your batteries are not being charged as you travel. Need more info. JMO
