MrWizard
Apr 08, 2018Moderator
My question is, I assume that I would need to cut off the positive feeds from the solar panels to the MPPT controllers before switching off access to the batteries?
you can use any switches rated for the amps and volts
i went with marine style circuit breaker
push the RED button and it disconnects, push or slide lever for reset(depends on the brand)
various brands and voltages available
https://www.amazon.com/Bussmann-CB185-40-Surface-Mount-Circuit-Breakers/dp/B01BDNVVSM/ref=pd_lpo_vtph_60_tr_t_2?_encoding=UTF8&psc=1&refRID=RQ3RA4SSH4AW07R4C6VC
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
