CA_Traveler
Apr 08, 2018Explorer III
BFL13 wrote:Definitely not advised as one panel has 30V and the other 90V.phemens wrote:
The controllers have set screws for the wiring, but I’d rather not have bare wires dangling around if I can avoid it, rather save fireworks for holidays ;).
The DC breakers sound interesting, I will look into those.
You can cover the bare wire end with a wire nut during the time it is out of its slot. To disconnect the array you can use either the pos or neg "array" wire.
If I had to do anything with my panel wiring (90V+) I would first turn off the panel switch then the battery switch and then disconnect one of the MC4 connectors on the roof. Then I could safely be a wire jockey.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
