Hard to say without a lot more information on your actual power use age and the charge profile of that converter. But generically speaking running a 650 watt generator for 2 hours every other day (average of 1 hour/day) is not fully recharging your batteries or anywhere near. Even under very lightly loaded conditions you would need to hold your battery voltage at around 14.4 volts for 2 hours a day to get close to 100% charged each day. If you really operated the way you said you did you got outstanding performance from those batteries and charger
No, the factory charge indicators are not good and border on useless for boondocking like you did. Get a multimeter and measure voltage directly. Lots and lots of posts on this forum by very knowledgeable people on battery charging.
