jimlouisesophie's avatar
Jun 13, 2014
Battery Discharging
My group 29 battery is discharging down to 12.34 after only 2 hours while dry camping with the fridge on propane. The fridge is 3 way, but is turned to automatic, and the gauge shows propane being used, which it actually is. The battery seems to be okay when not hooked up to the rig as I have charged it, left it aside and it still holds it charge. I put another battery in and it also came down to 12.34 after 2 hours, so the battery is not the problem. The only other thing I have on the trailer is a propane detector which is hooked up to 12V. After 12 hours the battery goes down to 12.24. Suggestions please.
  • Are you saying the charging voltage is 13.3v? At that voltage it takes about 4 days to fully charge a battery. If that's the voltage after charging, its surface charge and will slowly leak off. 12.66v indicates a fully charged battery.
    The fridge uses heat to cool the fridge. The heat is produced either by gas or by electric, Just feeling heat does not mean it is produced by gas. Can you see a flame?
  • Thanks for the replies. When I charge the battery, it goes to about 13.3 and settles at 12.66 the goes to 12.34 after 2 hours. I have not used any of my LED lights, just the fridge during this period. The Dometic fridge does not give me an option to turn to gas only, just auto, but shows gas. When I go to the fridge opening on the exterior, there is heat there, so gas is definitely being used.
  • RoyB's avatar
    RoyB
    Explorer II
    Your big drain is going to be your ceiling lights. Each 12VDC automotive type lamp will draw a good 1A DC CURRENT. Another hugh drain would be the furnace fan which draws around 4-5AMPS when being used.
    Your charged up battery should start out with 12.6-7VDC being fully charged.
    Here is simplified 30AMP Trailer Electrical Diagram showing what would be on the BATTERY if you are unplugged from shore power. As you can see alot of items are connected to the battery system so that your basics will run from the battery when not connected to shore power.
    Most people will want to have two batteries installed if they are going to do some camping off the power grid giving them at least 220AHs of battery capacity.
    We get by just fine with my 255Ahs battery capacity for camping off the power grid and we use just about everything we do at an electric site with the exception of the air conditioner and the high wattage microwave. We have planned it out to use all kinds of 12VDC items and 120VAC items running from an Inverter and have the battery bank only drop to 12.0VDC (approximately 50% charge state) by 8AM the next morning. Then we connect our 30A Shore Power cable directly to our 2KW Honda Generator using at RV30A-15A adapter and can re-charge our batteries back up to their 90% charge state in as little as three hours generator run time. Three hours generator run time usually fits in with all the camp ground generator run restriction times here on the East side of the US. Where we go the generator is never allowed to be used after 8PM.
    The main thing we did was to install a good multi-stage converter/charger unit, larger battery cables, additional batteries, and changed out the automotive type bulbs for LED boards.
    We have been doing this method of camping off the power grid since late 2008 and are pretty successful about it now.
    It does take some planning
    Roy Ken
  • How do you know the fridge is using propane? Most fridges set to auto sense there is 120v and automatically switch to electric, 120v. Take Niner's advice
    If you have a clamp-on ammeter measure the battery current.
  • You don't say what voltage your battery starts out at. More information is needed.
    Turn your fridge to "gas" only.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 18, 2025
