penguin149's avatar
penguin149
Battery disconnect - switch or fuse?
Looking to add a way to disconnect the battery on my 2019 Keystone Bullet 243BHS. There's a 6 gauge wire coming off the battery to a circuit breaker mounted on the frame, which leads to a second circuit breaker and then under the trailer enclosed by the coroplast. There is a second wire (12 gauge) from the positive side of the battery that has an inline 10A fuse and goes directly under the trailer. I pulled this fuse and can't find what it controls. Any ideas? The prewired rearview camera? The tongue jack is wired to the 2nd circuit breaker and has an inline 30A fuse.
What's the best way to disconnect everything from the battery? Switch (any recommendations?) or inline fuse (40A with 6 gauge wire)?
  • This is what I use and I have it on the negative cable without problems. Many will tell you this is wrong and it might be but it has worked on two trailers for 14 years.
    Battery switch
