Muddydogs's avatar
Muddydogs
Battery disconnect ?
First trailer with a battery disconnect but I assume that when the disconnect is pulled and I'm not plugged into shore power then my lights shouldn't work?
Today I installed a voltmeter and 12 volt charging plug, once I got to the wiring point I unplugged the shore power and pulled the disconnect. When I climbed back in the trailer much to my surprise the LED light were still on. I messed around with the disconnect a little but the lights stayed on so I pulled the fuse and went about the wiring. Once wired I played around with the disconnect some more and it appears that when the disconnect is pulled the voltmeter reads 12.2 volts and when the disconnect is not set the voltmeter reads 12.6 volts. When plugged into shore power I'm getting 13.6 volts as the battery's probably need a charge since the trailer has been setting for 2 weeks drawing power.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 20, 2026
