johnnydp1 wrote:
Bobbo wrote:
If I am plugged into shore power, that light stays on all the time because the converter/charger is still providing 12v power to the light. If I unplug from shore power, that light is only on while the battery is connected, and off when the battery is disconnected. That is normal operation and how yours SHOULD behave.
The operative phrase here is "unplugged from shore power."
True.
' Before, it would go off when I moved the rocker switch to STORE and I had the MH off AC power.'
Now I have to determine if it's the switch or the relay.
And, I told you it is the Relay(solenoid). Doug(giving you 38 years of RV Tech experience). PS, If your Car starter solenoid clicked when engaging the Ignition key, would you suspect it is the Ignition key lock was faulty? :h
