MEXICOWANDERER
May 17, 2016Explorer
The more insanely complicated a circuit is the more insanely aggravated the owner will become with frequent breakdowns. Exposed wiring is bad Juju. A harness is vulnerable as are exposed logic circuits.
This is about as simple and reliable as it gets. One positive cable from the chassis battery. One positive cable from the house battery, a short 16 gage ground wire and the unit works. Want pushbutton over-ride? Run a wire to a dash switch. For that I use a 12 gage for mechanical strength. XXL cross link 12-gage is damned near indestructible. When you are fighting your 5th episode with OEM garbage this little combiner will be looking at the sky whistling a tune of uncaring smirk.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
