time2roll
May 30, 2016Nomad
Do you have more than one positive wire coming off the battery?
afaik there should be one wire that goes to the cut-off switch.
If there are other wires I would discover what they are connected to and verify no current flow.
Next is the switch. Again need to discover what is connected to the battery side and what power does it use.
I would tend to rewire and adjust so that the OEM switch does as you expect. Or why have it at all.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
