agwill
May 30, 2016Explorer
First off if the trailer is plugged into 110volts all systems should work. If not plugged in to 110volts only the 12 volt systems will work until the battery disconnect is turned off. If wired correctly all 12 volt power will be removed from trailer.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
